Det stämmer att den inte pulviriseras, vem som nu tror det.Nu handlar det inte om att byta ut dieseln mot bensin .
Det handlar om att man inte ska få panik och tro att din diesel motor pulveriseras om du tankar fel .
The use of other products or mixtures may damage the engine beyond repair and consequently invalidate the warranty, due to the damage caused. If you accidentally introduce other types of fuel into the tank, do not start the engine. Empty the tank. If the engine has been run for even an extremely limited amount of time, you must not only drain the fuel tank, but the rest of the supply circuit as well.
