router 5776
Lasse-125
Trosa
På min routers display har det kommit en symbol som liknar ett sms.
Vad göra?:confused:
Sv: router 5776
Klicka på länken. När du loggar in via ipadressen kommer du till ett gränssnitt. anv: admin lösen: admin . Efter det kolla på menyerna efter sms och titta på det. (annars kan du bara flytta simkortet till en mobil och titta på dem)
How to Login to the Huawei E5776
Find Your Huawei E5776 Router IP Address
We need to know the Internal IP Address of your Huawei E5776 router before we can login to it.
Huawei IP Addresses
192.168.1.1
If you did not see your router's ip address in the list above. There are 2 additional ways that you can determine your router's IP address:
You can either follow our How To Find Your Routers IP Address guide.
Or you can use our free software called Router IP Address.
Now that you have your router's Internal IP Address we are ready to login to it.
Login to the Huawei E5776 Router
The Huawei E5776 has a web interface for configuration. You can use any web browser you like to login to the Huawei E5776. In this example we'll use Internet Explorer.
Enter Huawei E5776 Internal IP Address
Put the Internal IP Address of your Huawei E5776 in the Address Bar of your web browser. It looks like this:
Then press the Enter key on your keyboard. You should see a dialog box pop up asking your for your Huawei E5776 username and password.
Huawei E5776 Default Username and Password
You need to know the username and password to login to your Huawei E5776. All of the default usernames and passwords for the Huawei E5776 are listed below.
Huawei Usernames Huawei Passwords
admin admin
Enter your username and password in the dialog box that pops up. It looks like this:
Huawei E5776 login screen
Huawei E5776 Home Screen
You should now see the Huawei E5776 Home Screen, which looks like this.
Sv: router 5776
Fungerar den bra annars? Hur många antenningångar har den. Prioriterar den Extern WiFi?
Sv: router 5776
Den jag haft fungerar bra. Den har ett antennutgång (eller ingång) men kan inte ta emot extern wifi (vad jag hittat). Huawei E5372 är nog ett bättre alternativ om du vill använda det.
Tänk dock på att tar den mot wifi, så måste den kopplas via usb till datorn.
Sv: router 5776
Den fungerar jättebra. De övriga frågorna är jag för okunnig att svara på.
Men du kan lugnt lita på Stefans svar han kan detta.:)
Ps.
Stefan är ST i STACT. Ds.
Sv: router 5776
Ps.
Snällt sagt Lasse, och jag tror att jag har rätt, men 3G/4G är inte mitt huvudområde. Även om jag haft anledning att titta på just det de senaste veckorna.
//Stefan
