34000-77300 finns inte att få tag på i hela Europa!! Förutom eventuellt en kille i södra Bayern, för € 500:- !!!Tänkte byta ut fläktmotorerna för förbränningen art. 34000-55000 och varmluftsfläkten art. 34000-77300.
Men de var slut hos leverantören. De behöver bara hålla reservdelar i 10 år.
Finns det piratdelar att få tag i?
Update
Now running ok
It would seem that the motor from the later model combi is not a straight swap.
Measuring the resistance of both motors to compare , the original gives a reading of 2.6 ohms and the later gives a reading of 1.6 ohms. ( DC motors are a bit more complicated than this but it gives a guide).
Using current is volts divided by ohms
The original motor would pull 4.6 amps
The later motor would pull 7.5 amps
As the MOSFETs are happy up to about 5 amps it seems likely that the latter motor is what caused my circuit board problem.
To summarize
If you have a fan motor problem and a direct motor replacement is not available then the best repair would be to try replacing the brushes as detailed above several posts back
Men Freddy, det går INTE med den motorn som du föreslår!! 34000-77300 har svart-vita kablar. Alltså INTE röd-svarta.
