Ingen värme, felkod W45H, vad kan felet vara?
ROSBO
Tomelilla
Har fått ett problem. Har Truma värme i husbilen. Har fått en felkod W45H på displayn. Ingen elvärme funkar. Någon som vet?
Verkara vara en säkring 230V.
The 45h error code can also mean the 10 amp 230v cartridge fuse in the boiler has blown or the overheat protection has activated and needs resetting. This could happen if you turned it on without water in the boiler or in our case due to a power surge caused by a contractor working on the site mains supply
