Ovanlig husbil
Sv: Ovanlig husbil
Ikke fullt så ekstrem, men fikk mail om en ny husbil som er bygget her i Australia på en Unimog 12 tonn chassi, med alle opsjoner på chassi. Kul detalje en kan bygge om mellom høyre og venstre ratt på under 10 min. Bakkeklaring så det holder og endring av lufttrykk i dekkene fra førerplass.
[YOUTUBE]G4h5kfpK7F4[/YOUTUBE]
Full liste av spec:
12 tonne GVM
300hp
Portal Axles
Central Tyre Inflation & Monitoring (CTIS)
Left & Right Hand Drive (10 min change over)
4 Wheel Disc Brakes
Coil Suspension
8 Speed Automatic (Including Manual 3min engaging)
3 Lockers Front, Centre & Rear
Low/Low Working Gear Set
860l Water - 800l Fuel
Front & Rear 20,000lbs 24volt Winches
6 Step Electric Entry Steps
4 Point Hydraulic Jack System (Leveling & Tyre Change)
Heated Tanks, Batteries, Pumps and Water Lines
Front and Rear Snatch points
Anti-starvation, primary filtration fuel pick-ups
Bullet-proof run flat tyre system
Interior
“New” Wider Open Crawl-through
“New” 200mm Wide Body
“New” Control Console
Air Suspension Cab Seats
Double Forward Facing Rear and a Single side facing Seats, totaling 5 certified seat-belted seats
Queen Bed or Twins
212L Double Door Fridge /Freezer
2 x Sky-Beds, Sleeps 5
Fitted Wet Dry Vacuum Cleaner
Chainsaw and Axe Equipped
Artic System for minus (-40) includes heated water tanks, batteries and drying compartment for clothes etc.??
EarthGrill - 240 Volt outside BBQ, kitchen and sink
Kitchen Caddy with Light
68L locker fridge
Exterior
Fits inside Shipping Container
EarthAir - Rear Mounted Air Conditioner
Integrated 1600 PSI High Pressure Water Blaster
Large Out-door Screened Shower
“New” Motorbike Lift and Rack
“New“ touchscreens that can be intergrated with Ipad or Androids.
EarthData “New” Ultransonic Weather station feature incorporated in the touchscreen system
“New” 3 Axis pitch & roll GPS Gyrp Compass feature incorporated in the touchscreen system
Lithium Powered – Equivalent to 17 AGM Batteries (1500 AMPs)
Walk on Mono-crystalline Solar Panels 1000watts
DVR/GPS/4G solid state Celluar Hot spot & GPS Tracking system in real time, 45 Day recording including 5 cameras that can be seen anywhere in the world
80 Channel UHF
Upgraded Sound system featuring Hema mapping, Bluetooth & Iphone connectivity
3.2kva Inverter
Master Window & Mirror switching from both the Drivers & Passengers sides
Ewa & Jocke
Haninge
Man bli ju lite sugen
Ja jösses vilken skönhet! Helt otroligt vad GMC låg i framkant gällande produktionen av husbilar. Synd att de inte fortsatte inom husbilsgenren. Det skulle vara fantastiskt kul att få se en i verkligheten. Det kanske inte är så svårt med tanke på att det trots allt rullar c:a 8000 på gatorna.
Blir det ditt nästa projekt Pontus? ;)
Ha de gott?
//Jocke
Ja, og min far importerte en til Norge! Men myndighetene fant ikke ut hvordan den skulle tollbehandles så den måtte returneres til USA. Det skulle vært kult å ha denne meget spesielle bilen, stor V8 og forhjulsdrift sammen med luftfjæring på bakhjulene var en stor forbedring fra lastbilchassi som de andre hadde på den tiden. Dagens Fiat ALKO AMC mangler den store motoren, men har mye bedre drivstoff forbruk.
Langerstorm
Jag har personligen väldigt svårt att se tjusningen med en sådan tingest :)
Väldigt hög bränsleförbrukning, hög ljudnivå, den är nog inte miljöklassad så det blir fler och fler områden man inte får köra i osv. Särskilt terränggående ser den inte heller ut att vara.
Men det är tur att smaken är olika ;)
